ECU Cage/Holder removal
Does anybody know how to remove the metal cage/holder around the ECU?- I need to get at the numbers on the ecu underneath......cheers in advance
We cut a slot in the shear bolt heads , using a cordless angle grinder + 1mm cutting disc & undo them with a top quality screwdriver, fitted with a spanner.
They are very tight.
New bolts can be purchased if you want to look totally untampered.
Today 08:36 AM
» Replies: 15
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
