1din upto 2din upg on 53' 1.9d MS desire
Hiya peeps
Has anyone ever attempted an upgrade from the single 1 din radio unit to a double sized 2 din unit ever?
Or has anyone put in a double din'er (lol Smile ) into another position with the Column - maybe down in the well at the bottom near to the chargers ???
I'm trying to save money on still maintaining 6-7" screen for multi display of calls, satanic, rear cams etc but trying to avoid having to fork out the premium for having a pull out large screen for a single din head unit, the double din versions can be over half price of singles!!!
Any advice such projects would be gladly received Smile
I dont see how it would ever fit in the original place. So if you insist on a 2 din radio (instead of a 1 din pull out screen) then I would try to make something in the space near the chargers.
I would make a plywood box wich would fit under the overhang. Give it a slight angle so you have a good view at the display without the sun blocking the view.
Enough room too even keep the cupholders. The wiring and antenna may need to be extended a bit though.
2007 Peugeot Partner Zenith RIP Sad
2010 Seat Ibiza ST
(09-06-2017, 11:48 AM)mission Wrote:  I dont see how it would ever fit in the original place. So if you insist on a 2 din radio (instead of a 1 din pull out screen) then I would try to make something in the space near the chargers.
Yep that or some nicely cut and bent steel/ally - if I was feeling adventurous I could try cutting it to fit the unit to slide into under its own grasp!!!
Could use steel, I wouldnt as it will be harder to work with, a lot harder to make it blend in and attatch to the dashboard.
2010 Seat Ibiza ST
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
Rear view mirror
02-12-2025 08:19 AM
Gear number display
Last Post: MarcoLingo
29-11-2025 09:02 AM
25-11-2025 04:20 PM
Lapik's 5-th Berlingo
25-11-2025 08:21 AM
ë
24-11-2025 09:08 PM
Welding precautions
24-11-2025 12:37 PM
driveshaft tripod joint spring
24-11-2025 12:31 PM
