08-06-2017, 12:27 PM
Hi Yeah,
I've got a 2009 Berlingo (Mk 3) and have a leak where the feed and return pipes are fitted to the Steering Rack. Both these pipes are fitted to the rear of the area where the steering column bolts onto the steering rack, between the rack and the engine bulk head. A very awarded place I might add.
The original washers fitted were Green (Upper Pipe) and Brown (Lower Pipe) and when I rang Citroen they told me there was a seal kit available for this (Containing 6 items) at a cost of £20 plus the VAT.
I thought this cost was a bit much as I only needed two small O-Rings and decided to try to source these in the regular outlets where your'd expect to get O-Rings. Anyway after a lot of trials with a variety of O-Rings (total O-Ring Expenditure so far = £3) it is still leaking.
So I am now wondering will the correct seals do the job or am I missing something here?? At this point I am willing to purchase the seal kit but am now thinking that there might be something else wrong. Has anybody any experience of this area and these seals??
Any advice will be greatly appreciated...
