Multispace flap hinge fixed..
I have refitted the rear roof flap on my Multispace using a small hinge and some small nuts and bolts..
 I cut a slot in the plastic using a dremell just big enough to slide the hinge into. The two remaining plastic original hinges I have left on so the flap still opens and closes using the original catch but hinges on the new metal hinge.
 I hope the pictures come out OK...
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
Very tidy job. Looks quite nice.
Cheers 3rensho..
  I am going to swap the stainless screws for plastic ones and see if it looks any better..
I didn't swap out the bolts for plastic ones, I decided to fit covers over the bolts instead.. Looks good..
Did you find some glue that works on ABS?
  • G1nganinja
Glue ? there is no glue used.
 I cut a slot in the plastic just large enough for the hinge to slide into. if you want to secure the hinge glue could be used but I don't feel the need to..
Thought that the bottom picture showed some glue? Perhaps it's something that was already there from the factory.
Yup there is a wavy yellow line in the bottom pic which is the original glued section of the roof panel..
Yesterday 05:21 PM
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
