10-06-2017, 10:05 AM
Hi guys
Yes i have asked for help in a past post but still on going.
I have a citroen berlingo 2002 model
1.4 engine with AC Australian delivered
Problem
The car is overheating when in traffic with temp gauge showing 3/4 hot and the only way to bring temp down is to switch on the air-conditioning which
Keeps both fans running all the time.
Even with that, temp gauge only goes down to just above half.
So what I have found.
Seems fans are coming on too late
(Gauge shows 3/4)
and not staying on long enough and fans don't seem to be strong enough
What I have done
(Replaced)
new temp sender on thermostat
New thermostat
New radiator cap
New 3 relays on fan shroud.
Cleaned all electrical connectors.
Checked all earth points.
New bottom seal on radiator
Flashed out whole cooling system.
Bleed all 3 bleed screws and jacked car up on battery side to force air out.
Flashed out heater matrix.
Had mechanic test for blown headgasket and all good.
There is no oil in cooling system
There is no water in oil.
There is no combustion gases in cooling system.
With the 3 relays.
When fans on without air-conditioning
If I pull out the top right one fans go off same goes with the bottom relay fans go off,
But if I pull out the left relays fans stay on.
I have also been told it has 2 speeds and might be the bitron?
For the life of me can't seem to find this so called bitron
If i switch off air-conditioning and drive without stopping temp comes down
So indicates to me must be fans or temp sender.
I have been told that even though I changed the temp sender with new one that the new one could also be faulty.
Once again sorry about the long msg but thought more I explain the easier it would be for people to understand.
Please help I'm at my wits end.
Problem
(Gauge shows 3/4)
What I have done
(Replaced)
New thermostat
New radiator cap
With the 3 relays.
