Thanks Received: 3 in 3 posts
Thanks Given: 8
Is this a common fault? I'm on my 2nd van of the same year and model (2012) now and they both did it. Its like the aerial isn't connected. I struggle to pick up local radio stations
Fire bad, tree pretty
Thanks Received: 3 in 2 posts
Thanks Given: 4
Do you have a USB adaptor plugged into the 12 volt cigarette socket ? If so, try removing it.
Some of these adaptors are poorly designed and radiate hash all over radio spectrum, giving exactly your symptoms.
The following 2 users say Thank You to nicko for this post:2 users say Thank You to nicko for this post
• Kez, Matt Haigh
Threads: 7
Thanks Received: 26 in 24 posts
or do as i do never switch it on ;-)
Threads: 9
Thanks Received: 11 in 6 posts
Thanks Given: 9
I have a 98 M49 and the reception was awful on the original head unit. When I got round to replacing the HU I also looked at the aerial connection above the shelf and was surprised to find that the car had two aerial cables - one wasn't connected to the antenna! At the head unit end the two wires had the different aerial standard connectors (one ISO banana, the other DIN) and the one I was using was not the one attached to the aerial.
Obviously a lot has changed from 98 to the B9 but the French are still French. Maybe check at the antenna connection in the roof?
Thanks Given: 8
Oh I'm going to change the speakers.. but this problem is signal related. I do have a usb converter, so will give that a try
Threads: 16
Thanks Received: 54 in 17 posts
Thanks Given: 4
8
I have a Myway Rneg radio and the reception is also poor in fact I think the RD4 was better plus is has more pre-sets. I agree with ”Nicko” a USB connection can cause problems I have two Dash Cams one with no problem the other I do, so I have ordered some small clip on RFI Noise Ferrite filters hoping this will resolve the problem plus fitting a VW aerial amplifier
