  • 1 Vote(s) - 5 Average
Wiring diagram foe egr
Anyone have a wiring diagram for the egr connector 1.6 hdi 110 ?
If you are thinking of "fooling" ECU by connecting something, you are out of luck.
Already tried that.
It must be disabled in ECU software.
I have been running my 1.6 HDI 90hp with software disabled EGR for some time now.
Best regards,
brajomobil
I'll keep it as a garage fitted new egr, I just wanted to check 5v references. I looked on diagbox and think I have the pinnouts now. Looking at live data I now think airflow sensor or similar is throwing up the egr codes.
(14-06-2017, 09:24 AM)richieski Wrote:  I'll keep it as a garage fitted new egr, I just wanted to check 5v references. I looked on diagbox and think I have the pinnouts now. Looking at live data I now think airflow sensor or similar is throwing up the egr codes.
At what RPM does fault comes up?
You can check when you click on fault and the more info
Or you can post screenshot from faults more info...
Also check if your vacuum is operating turbo wastegate.
Both faults, EGR and pressure sensor can be triggered with bad vacuum on wastegate.
Best regards,
brajomobil
Please find details attached
Attached Files Thumbnail(s)
It seems you have bad EGR. You can try to clean it but it is likely
that you need to replace it.
Here you will find more info: https://www.berlingoforum.com/thread-12042.html
Best regards,
brajomobil
I had it replaced, do you think they put a faulty one in?
New one is OEM or Chinese ?
Chinese I bought did not last long...
OEM is made by Valeo.
Best regards,
brajomobil
Not sure, garage assured me it was VALEO equivalent.
Please take a look, you can clearly see i am not getting air flow from 1000 rpm to 2000 rpm. It actually dips down
Rattling calipers
Today 05:25 PM
eolys
Last Post: magoo1
15-05-2026 06:02 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
