Threads: 20
Thanks Received: 7 in 7 posts
I've been googling and not really sure on the results, 'Roofbox' say berlingo can't have them.
Any ideas folks, also it is for two electric bikes..
thanks
Multispace B9 2009 1.6HDi
Threads: 28
Thanks Given: 78
There are plenty on eBay.
Mark
Sent from my LIFETAB_S1034X using Tapatalk
Threads: 20
Thanks, there seem to be some from £30 to £90 then jump up to the hundreds.
Bikes are 22kg each so cheap ones are not up to that weight .
Threads: 7
Thanks Received: 61 in 55 posts
Thanks Given: 16
I don´t know about rear bike racks (actually I have seen some nice ideas to adapt a model made for a VW transporter to Berlingo/Partner that can take up to 4 bikes), but I have a roofbox kit that I install on my Modutop roof. The instructions say I can have up to 70kg total weight on the bars (35kg in each). More than enough for 2 bikes...
Threads: 20
15-06-2017, 11:45 AM
(This post was last modified: 15-06-2017, 11:46 AM by magoo.)
Thanks for the info, Luis how do you get the bikes on the roof? serious I'd need a ladder (I'm 5ft 8in).
I saw a pic of the VW one, you have to drill holes etc (not keen on doing that) and couldn't tell if that needed a tow bar.
Spoke to Citroen and a rear rack is a big No No unless tow bar fitted,
Threads: 20
Thanks again Luis, I'm out for the day but will read your links tomorrow.
Threads: 9
Thanks Received: 4 in 4 posts
Thanks Given: 2
I personally wouldn't have bikes off that long pivoting rear door incase it pulls it out of line(?). I feel it should be towbar mounted or roof bar/carrier. I have the later and I use a small footstool when installing a bike.
Threads: 7
Thanks Received: 27 in 25 posts
I have a roof rack that im going to fit to the berlingo onto the orig roof cross bars but this rack has a mechanism that you stand at the side of the van press 2 buttons at head height and it slides out to the side and drops down at an angle to load and unload i will easily get a bike on there or ladder depending on what i need to carry
Threads: 54
Thanks Received: 81 in 75 posts
Thanks Given: 147
7
I assume there is some reason why you don't put your bikes inside the vehicle? are you using all the rear seats or carrying lots of other luggage? with the centre rear seat and the centre console removed you'll get both your bikes in, upright with wheels on, and still have luggage space either side. I often take all 3 rear seats out and fit up to 4 bikes in.
Matt
previous
2016 1.6 HDi 100 XTR Grey Met
2010 1.6 HDi 105 XTR Gold Met
