16-06-2017, 06:19 AM
Hello,
I have a 2013 C4 with a 1.6 eHdi DV6C engine (same as the Berlingo)
I will take it to get remapped, and i am thinking about what to do with the EGR valve.
I want to leave the DPF working, what would happen if i disabled the EGR valve, but left the DPF working?
Some people say that the EGR is used in a DPF regeneration cycle, some say it is not;
Some people say that turning the EGR off will make the DPF clog much quicker, other people say its the complete opposite!;
Some people say that the EGR valve plays a key role in the DV6C engine and that without it the engine will start acting up in all sorts of ways.
So could anyone with the knowledge tell me what will happen if i remove my EGR, but leave the DPF functioning, assuming i do a proper remap?
1. What effect will it have on the DPF lifespan and regen frequency?
2. What effect will it have on the engine itself, if any (engine temperature, higher/lower wear due to higher/lower temperature of certain parts)?
3. Any other advantages/disadvantages (cleaner/dirtier oil, more/less turbo lag, etc.)?
Thank you.
Thank you.
