Threads: 9
Thanks Given: 316
15
Ive seen this before somewhere either on this forum or the citroen forum - im sure a different seal rectified it - was the seal genuine?
Threads: 8
Thanks Received: 7 in 6 posts
Thanks Given: 2
The seal I bought looks exactly the same as the one you are referring to there if the pictures online are correct. It has the same nylon guides, if I assume correctly those are the white "teeth" on the inside of the seal. I think it´s an "original" part though. I didn't´t look at the box it came in very closely.
I used a large socket, 40mm or so I think to knock it in.
Threads: 123
Thanks Given: 250
34
Yes that's the one that I bought. Seems that you have larger sockets than me!
The original seals are 11.3 mm wide, but Citroen now specify a more common 10mm wide seal, those are normally what you see on ebay. As you've used the Elring seal, the only things I can think are that it got damaged by the shaft or it's somehow not seated properly.
Maybe get a 40x58x10 seal & try again?
Threads: 68
Thanks Received: 26 in 22 posts
Thanks Given: 22
I don't understand what the nylon bit is for ? I have genuine seals and they don't have it, the seal itself is thicker and is better quality than a standard seal.
Did you rub some gearbox oil on the shaft and seal before assembly ? Always wise to lube before insertion..
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
Threads: 5
Thanks Given: 4
21
If you are pulling the shaft out then it might be worth taking a close look at the shaft where the seal runs - it might have a wear groove, or the new seal is sitting on a previously unused part of the shaft which may benefit from polishing up with some emery paper or similar. Also...is the seal lip facing inwards (?) - by the sounds of it, with your experience, it is!
Threads: 8
Thanks Given: 2
I can't feel any resistance when inserting or pulling the shaft out at all. Strange.
The berlingo has developed a rather bad clutch judder since replacing the clutch so i'm afraid I will have to do surgery on it one more time. Can't imagine what the problem is though.
