Threads: 68
Thanks Received: 26 in 22 posts
Thanks Given: 22
I've just changed the clutch in my Multi, I bought it with a clutch judder that I recon was the result of a long term cam box oil leak getting in through the bell housing and contaminating the clutch...
Any how the oil that came out was thicker than BV and red in colour. I have put Total Gear 8 in and the gearchange is back to being smooth again...
Just out of interest what gerbox oil is red ?? Just interested..
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
Threads: 68
Thanks Given: 22
Is ATF any good as a gearbox oil then ?
I thought ATF was for auto box and power steering..
Threads: 5
Thanks Given: 4
21
ATF has been used as a gearbox oil - for example Rover gearboxes mated to the V8 ran on it - but why it was used in those boxes, I'm not sure, and certainly the boxes didn't fare that well under heavy use or when power was increased.
Premature bearing wear, synchro issues and general noise were not uncommon. I rebuilt a number (too many) of those gearboxes and found no difference if I swapped over to using a standard gear oil.
Later boxes used a horrendously expensive Land Rover product, with much the same results as ATF.
If you had a red puddle on the garage floor then you knew it wasn't an engine oil leak, and ATF certainly creeps and dribbles. How it might end up in a Berlingo - maybe someone read the wrong chart in Halfords!
Threads: 68
Thanks Given: 22
Cheers oilyrag..
I have a MGF and forgot about the ATF in PG gearboxes although I have bought the TF94 oil, 5l at £32 makes it more expensive than Total 75/80 gear8..
That reminds me the clutch is slipping in my MGF so that needs doing too..
Threads: 17
Thanks Received: 8 in 4 posts
My old Volvo 240 specified ATF for the 5 speed manual M47 gearbox mated to later redblock engines. No idea why.
I'm sure I read a suggestion somewhere of putting it in a gearbox to quieten a worn synchro (but then you can find most things suggested for that purpose if you look hard enough: thinner gear oil, thicker gear oil, ATF, engine oil, extra virgin olive oil...).
