Radio and ignition behaviour
Threads: 16
Thanks Received: 8 in 4 posts
I've just swapped my DAB radio into the Berlingo. At first every time I turned the ignition off, it had to be retuned when it was turned back on, so was obviously losing its unswitched feed.
I swapped the switched and unswitched feeds and now this problem is gone, but now the radio has to be switched off manually when you get out of the car. Is that normal?
Since I put the radio in, I've noticed the little display in the centre of the dash doesn't work properly. It scrolls the message e.g. "Front left door open" and then when you shut the door it freezes, so it might display "r open" and the time (which doesn't change). It's only really annoying because the clock stops and I have to open a door to get the right time!
While we're on electrical stuff, if I unlock and only open the tailgate, the car locks itself 30 seconds or so later. The rear courtesy lights also don't come on when you open the tailgate (only the sliding doors). Is this usual behaviour or is the meet something wrong with the tailgate open switch?
That's probably enough electrical questions for now!
Thanks Given: 188
23
You need to get a patch lead to get the centre display to work, have a search on the site there is plenty about the subject and leads required.
Are we there yet?????
Threads: 16
Admittedly I didn't search before I posted because I was on my phone and being lazy
Searching for "centre display" brings up a couple of threads, but no-one with the same as mine. "Patch lead" returns no results. Can you suggest what else I might search for?
Cheers
Threads: 41
Thanks Received: 408 in 365 posts
Thanks Given: 134
31
23-06-2017, 08:01 AM
(This post was last modified: 23-06-2017, 08:02 AM by brodfather11.)
" I swapped the switched and unswitched feeds and now this problem is gone, but now the radio has to be switched off manually when you get out of the car. Is that normal? "
It is normal on mine , If I leave it on there is a delay of about a minute before it switches itself off.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 16
(23-06-2017, 08:01 AM)brodfather11 Wrote: If I leave it on there is a delay of about a minute before it switches itself off.
I thought that might be the case, but I tried leaving it and didn't see it go off. Perhaps I didn't wait long enough, I'll have another go.
Thanks Given: 188
23
Just type Radio in the search box and you will have many happy hours of surfing.
Threads: 16
(23-06-2017, 06:54 PM)Tomcat3 Wrote: Just type Radio in the search box and you will have many happy hours of surfing.
Having read all the relevant-looking threads that a "radio" search throws up back as far as 2011, I'm just going to give up and stick a digital clock to the dash somewhere, and be glad that changing my radio hasn't stopped the car starting or any of the other myriad problems it seems to have caused people!
Threads: 16
I parked up today and locked up with the radio on while I sorted some stuff out before leaving the car. Sure enough the radio went off after a couple of minutes. Tried it twice and it worked both times.
Before I left the car, the radio having switched itself off, I pressed the lock button on the remote key fob just to make sure it was locked. Indicators flashed to indicate it was already locked. And the radio turned back on. I give up trying to find logic in it.
Threads: 16
(25-06-2017, 07:23 AM)drc200 Wrote: if your courtesy light doesn't light perhaps the boot switch is not working?
Suspect that's the case - funnily enough I had the exact same problem with my last car.
Thanks Received: 13 in 12 posts
Thanks Given: 4
Over the past few weeks I became pretty good with the electrics when swapping my old radio.
I have used this adapter for the stalk controls and display controls.
Connects2 CTSPG006
My display still had the same problems as yours, wich I fixed by unplugging the display cable (take off the trim arround the display and there is a cable on top), drive arround a few minutes, stop and reattach the cable and all should work again. Propably disconnecting the battery would do the same trick.
I have not tried this without the adapter, so not sure if it would work, but cant hurt to give it a try
2007 Peugeot Partner Zenith RIP
2010 Seat Ibiza ST
M59 unlocking itself
05-11-2025 04:06 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
03-11-2025 08:08 PM
02-11-2025 07:53 PM
Boot liner with 7 seats
31-10-2025 07:57 PM
Last Post: Buki
31-10-2025 07:26 PM
31-10-2025 03:06 AM
» Replies: 40
