23-06-2017, 02:34 PM
My first post on this forum, so please be gentle.
I am having problems identifying the correct replacement rear wheel bearings for my 2005 Berlingo Enterprise 19D van.
I have dropped the back axle and sourced a replacement because a torsion bar was snapped and the trailing arm bush/bearings were gone.
Brake backplates were taken off the old axle as it is an ABS model and fitted to the replacement.
I then set about buying a pair of hub kits because Haynes says the hub will be goosed by removal.
Both a citroen dealer and ebay sellers describe ABS hubs as being "toothed", some 44 teeth and others 29. As you will see in the pic, there are no teeth on my ABS hubs, more like a ring of compound on the inner flange.
Can anyone explain what is going on please.
Does the compound contain embedded bits which are read by the ABS sensor? If so will a toothed hub be compatible with the sensor.
Any advice welcomed.
[Image: 20170623_134557_zpszd9mwzfy.jpg]
