Tailgate trim panel removal.
Hi
Just purchased an 08 plate multispace to convert to a camper.
And I was just wondering how to remove the large trim panel from the rear tailgate
Apart from the obvious yanking it off, knowing how fragile the clips are.
Thanks in advance...
A set of these make panel removal easier and don't scratch the paintwork http://www.ebay.co.uk/itm/5-Piece-Car-Do...SwxehXOfW0
And you will need some new clips as they tend to break removing them, easily obtainable from a motor factors or ebay.
  • squiddley
I would order a few spare clips before you start  as they will be very Brittle and will break easily. I had that problem when I was removing my trm on my 2007 and nothing worse than having stop work and to get the clips
Thanks for the advice. I shall order some , thank you
(24-06-2017, 10:44 AM)squiddley Wrote:  Thanks for the advice. I shall order some , thank you
Clips break anyway
I just sunk a self tapper near one of the broken clips, as the clip was causing a rattle. I would have needed to pull away a good bit of the trim to replace the clip, which wasn't worth it at this stage. I can live with the self tapper.
I see this is quite old but thanks anyway, helped me out, great stuff
There was a link to ebay but it's expired, what was the tool called please.
I have a kit like this, though it has a lot more items and was a bit dearer. Just search eBay for trim removal tool.
https://www.ebay.co.uk/itm/164299786749
triangle light
Last Post: norm1
Today 12:20 PM
Yesterday 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
