Rear brake disc rotor replacement which size socket? HELP
Hi all I replaced the rotors and discs on the front of my 2012 enterprise recently and want to do the same on the rear. I haven't got big sockets only sockets going upto 27mm I think. Would like to know what size the hub nut is under the bearing cover on the rotor so I can change it on the day without being stuck. Also why is the rear on a bearing and thus they are like twice as expensive to buy the rotors... I understand ill have to replace the nut too, this is the nut I want the size of so as to buy the correct socket but cannot find the size anywhere not even in the Haynes.
So in summary what is the size of socket I need to get the hub nut off and does it need to be a deep socket any other tips?
Thanks.
(29-06-2017, 09:23 PM)jamesfox Wrote:  No tips.
Order new ones and get a socket to fit. 36mm according to eurocar.
Can you not simply measure it ???? ( measure across the flats )
(30-06-2017, 11:14 AM)geoff Wrote:  Can you not simply measure it ????  ( measure across the flats )
Yeah it was 36mm and fookin tight as a nun!!
OBD Red discussion
Yesterday 08:29 PM
» Replies: 32
2012 1.6HDI throttle position sensor
Last Post: mtd247
Yesterday 07:58 PM
advise please
Last Post: tricky2
Yesterday 06:43 PM
Central Locking, Is it aftermarket or stock?
Yesterday 04:41 PM
2nd Eolys tank, still showing risk of particle f...
Last Post: hofhomer
Yesterday 03:34 PM
Limp Mode - Low Power
Yesterday 09:51 AM
» Replies: 27
Top clock screen upgrade.
Yesterday 09:24 AM
Wire to tap into for DRL install
Last Post: Sahloul
03-12-2023 04:23 PM
How much adblue and where is it best to buy it
Last Post: dickl
03-12-2023 03:02 PM
Any opinions on Eolys .
Last Post: Pepito
03-12-2023 02:54 AM
