Threads: 3
Thanks Received: 6 in 4 posts
Thanks Given: 4
Hi. I have a slow start problem with my 08 1.6 hdi. Only when left for a period of time does it slowly start.
I have read air leak back so therefore checked the primer.
When I squeeze it I can hear air gushing out. Don't no if this is right or wrong. Also it don't matter if car left for period of time or after been drove. Car drives fives.
Could someone either try there's or inform me as to what's going on.
Thank you
Threads: 7
Thanks Received: 26 in 24 posts
i had a problem on escort van real pain to start first time in the day but ran fine after that turned out to be a bleed screw on the top of the fuel filter the threads had gone in it allowing the diesel to run back to the tank over night it all looked fine till i tried to nip it up a little bit more. Took screw out little bit arraldite on it screwed back in problem gone
The following 1 user says Thank You to Oi69 for this post:1 user says Thank You to Oi69 for this post
• j.ted
Threads: 15
Thanks Received: 102 in 92 posts
Thanks Given: 15
6
Hi
Bulb on ours is not 'squishy' after a week lying idle (just back from 7 days away) - started first time 'on the button' this morning.
Sounds like you have the leak back problem??
Our cars 2008 1.6 HDi 92 Berlingo (His) RIP 2019
2008 1.6 HDi 110 Mini (Hers)
2008 1.6 HDi 143 Mini (His)
The following 1 user says Thank You to GraemeT for this post:1 user says Thank You to GraemeT for this post
• j.ted
Threads: 30
Thanks Received: 13 in 8 posts
Thanks Given: 2
Primed mine after cleaning inlet ports, no air gushing on mine
The following 1 user says Thank You to richieski for this post:1 user says Thank You to richieski for this post
• j.ted
Threads: 3
Thanks Given: 4
Hi again. Ok since writing and asking for help I've worked on fuel primer and can confirm it's fine. I've fitted a inline non return valve and the diesel stayed on both sides of valve even for a week. I've recently replaced the egr valve for a brand new 1 off eBay.
However my intermiting starting problem still exists. I've looked at using the cheap Bluetooth obd connector and checked codes. It's showing p1462. Anybody any experience with this and how to solve it.
My berlingo is the b9 2008 hdi vtr with no air con.
Please help.
Thank you in advance.
Threads: 3
Thanks Given: 4
Hi oi69 could you please inform me what exactly that Is? What part I need to replace?
Threads: 41
Thanks Received: 405 in 362 posts
Thanks Given: 134
31
(18-09-2017, 10:48 AM)Oi69 Wrote: (16-09-2017, 05:05 PM)j.ted Wrote: Hi again. Ok since writing and asking for help I've worked on fuel primer and can confirm it's fine. I've fitted a inline non return valve and the diesel stayed on both sides of valve even for a week. I've recently replaced the egr valve for a brand new 1 off eBay.
Please help.
P1462 A/C pressure sensor circuit Voltage High
He does not have a/c.
found this
Citroen C4 P1462 Code Meaning :
P 1 4 6 2
OBD-II Diagnostic Powertrain
(P)
1 =Trouble Code For Engine Fuel And Air Metering
4 = O2 Sensor Heater Circuit Malfunction
6= Cylinder 4 Contribution/Balance Fault
2= Glow Plug/Heater Circuit 'A' Malfunction
OR this
P1462 -
intermittent fault - EGR valve learning
OR this P1642-
Took it to the garage, where they found the code P1462 - which points at the EGR valve - probably gunged up.
OR ,
P1462 egr electro valve position
So take your pick
If you can get access to a proper Lexia , that will give a better idea where your fault is. The cheap dongles don't always work properly. The A/C code is probably for a petrol engine.
I think its your egr or the egr control or air vacuum pipes maybe leaking or not fitting right. It could also be the air mass sensor.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 3
Thanks Given: 4
Hi brodfather11. Wow that's a defo great description on the codes. It's explaining a few issues I may have.
Today I done a leak off test (sit version) and found injector 2nd in from gearbox side to be pouring diesel out. I then looked on diagnostics again to which now have the engine light on but also found code p0204.
I've bought on eBay today a good second hand injector and seal kit. Hoping to fit this at weekend and will update further. Fingers crossed this clears/sorts alot of the problems out.
Threads: 3
Thanks Given: 4
Hi. Like I said I am updating info.
The good condition and tested used injector has fixed my starting problem however I still am seeing this code p1462.
I don't have a engine management light on.
