Threads: 20
Thanks Given: 7
15
I use the pocket in the passenger footwell where the USB cable plugs in. With the touchscreen and CarPlay there is no need for a phone holder.
The following 1 user says Thank You to Tree for this post:1 user says Thank You to Tree for this post
• davester65
Threads: 12
Thanks Received: 6 in 6 posts
Thanks Given: 4
(01-07-2017, 08:09 PM)davester65 Wrote: This has probably been covered before but as a newbie thought i'd post a thread about which phone holders you all use? Pics Welcome.
I found this one by Belkin in Maplins, expensive @£30 but perfect for my van (cheaper versions are available on fleabay)
What you got in yours?
Looks good is it easy to remove
2012 XTR Berlingo 1.6 hdi e semi auto wicked red
2016 Nissan Qashqai 1.5 Tekna manual Ink Blue
Thanks Received: 7 in 5 posts
Thanks Given: 1
You could stick a plastic disc on your dash and they stick the holder on to that instead of the windschermen. Sold where they sell satnav.
Threads: 54
Thanks Received: 81 in 75 posts
Thanks Given: 147
7
I use one of these, purchased on ebay, it pushes vertically into the power socket beside the gear lever, there is hand clearance to change gear with phone in landscape mode. it powers the phone and provides further USB sockets for other devices. Its not the most robust construction I've ever seen but it works fine and its quite cheap (approx £7).
Matt
previous
2016 1.6 HDi 100 XTR Grey Met
2010 1.6 HDi 105 XTR Gold Met
