Clutch number two... Having fun yet ?
Hiya all..
  Two weeks ago ( in the blistering heat ) I fitted a new clutch ( Quinton Hazel ) with genuine clutch fork and genuine thrust bearing / 3x engine mounts / Driveshaft seals / front strut top mounts / gear selector rods / wishbones / cleaned the starter motor / de-rusted and painted my Berlingo multi.. It took 3 days in 34 deg heat.. A clutch cable is still needed, I'll get around to it soon..
  Today I have been working on my Van, I changed the clutch ( LUK ) with genuine clutch fork and thrust bearing and front strut top mounts, started at 1130, finished 2030.. A day well spent.. The clutch I took out was a Valeo clutch and was Stiff, it had 6 springs in it of different strengths and the thicker heavy ones were almost worn through and on the point of snapping, the LUK and the Quinton Hazel had 4 springs.
  I have found something very interesting... The new clutches give a different feel, the Quinton Hazel clutch gives a heavy clutch pedal but the bite point is easy to find and the LUK clutch gives a very light clutch pedal, the light pedal is vague and is difficult to feel the bite point. I thought this might be of interest ..
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
[-] The following 2 users say Thank You to ajcommercial for this post:
  • RevManiac, ron
Yesterday 05:50 PM
15-11-2026 05:06 PM
15-11-2026 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
