Steering technical question..
Any advice on how floppy a track rod should be ? I'm talking about the rod between the steering rack to the track rod end..
  My van has 170k under it's wheels and the rods are very sloppy but there is no signs of knocking or play, just very lose.
 My Multi has 120k under it's wheels and the rods are stiff to the point where they hold up their own weight if you disconnect the track rod end from the hub..
 Are they easy to change ? Have you changed some ?
  What do you recon ?
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
The tight ones may be dry.I ease the boot from the stem & spray m/cycle chain lube in them.Don't remove from the body,just ease away below the threaded stub.
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
