does my Berlingo have TPMS?
I'm looking to upgrade to alloy wheels on my 2015 1.6 hdi 75 Berlingo Van, does my van have TPMS? as I can't find any settings in the 7" touchscreen or a reset switch anywhere? Can anybody help with this?
Should be able to tell by looking at the valves. TPMS valves are usually alloy.
Malcolm.
2001 1.9D Multispace.
[-] The following 1 user says Thank You to malgpz900 for this post:
  • davester65
Possibly not then? The van has stock 15" steel wheels and definitely rubber (bendy) valves.
You could always reduce the pressure on one of the wheels and see if any warning comes up, just to be 100% sure.
Malcolm.
  • davester65
Thanks doofer, you wouldn't happen to know if fitting aftermarket alloys (17") and tyres will make the TPMS (if fitted) behave weirdly or stop working altogether?
(03-07-2017, 02:48 PM)davester65 Wrote:  Thanks doofer, you wouldn't happen to know if fitting aftermarket alloys (17") and tyres will make the TPMS (if fitted) behave weirdly or stop working altogether?
So i went and did the unmentionable.....i read the owners handbook  Blush .....and my van does have TPMS (sensors fitted to valves inside the wheels), a quick call to the guys who are going to fit my new alloys confirmed they are transferable (at no extra cost...bonus!!)
Problem solved  Smile  MOT failure avoided  Smile Smile
[-] The following 1 user says Thank You to davester65 for this post:
  • Disco55
ASDA AdBlue 10 January 2026
Yesterday 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
Blower fan
04-01-2026 09:58 AM
