Hi.
I have searched a lot on the wide internet about how to identify the correct steering rack for my 2005 Berlingo Multispace 2.0hdi, but without any luck.
Does anybody here know how i get the correct one for my car?
Thank you :-)
Threads: 52
Thanks Given: 87
5
Welcome MGT to the forum. As a first guess I'd take the VIN to a dealer and get the info. I'm sure others will be along with more ideas.
Threads: 58
Thanks Received: 691 in 589 posts
Thanks Given: 174
44
Local proper motor factors will sort you out ............. not halfords etc !
Serieal Berlingo owner
Threads: 0
I have exactly the same problem (along with needing a new rear axle). What was the direct rack for your model? I have a 2005 hdi 2.0 multispace forte.
Threads: 0
You might have to get a mechanic to identify which rack you have as
There are 5 possibilities a d you can't tell from the chassis number alone.
Threads: 0
