Crossover in Berlingo 1.8i from 1999?
Hey, guys!
I recently got myself my first car, a berlingo 1.8i multispace from 1999. Due to the lack of quality in its current audio system I'm in the process of installing a new one.
I've installed audio systems before so i'm quite familiar with it, but i have a question.
Does the car already have a crossover device built-in for the dash-speakers and the door-speakers??
I'm concerned whether or not I should install a crossover.
Actually, i got another question. There's two offers where you can buy a set of front speakers. Both speakers are almost the exact same, the only difference is that one has the tweeter separated and the other does not. The offer where the tweeter is separated, is £30 more expensive than the one where it's not.
Hope it makes sense.
Thx in advance
Hannibal
(07-07-2017, 08:48 PM)hann5647 Wrote:  Hey, guys!
Thx in advance
Hannibal
Pretty sure there's no crossover, otherwise the poverty-pack like mine (1.4L, manual windows etc) would only put out high tones to the dash speakers and you wouldn't hear low tones at all.
I haven't checked, but maybe the dash speakers are connected in parallel with the door speakers (it looks like that from the wiring harness behind the head unit). Since Peugeot only give you 25W or thereabouts for the speakers, they could have used 8 ohm speakers. One 8 ohm speaker on 12v will be 25W, but two of them in parallel makes 4 ohms, which will be 50W at 12v - standard maximum output for a headunit per channel.
Really you shouldn't have to worry about it. There's already wires in the doors for speakers, so just use them as is. My van had aftermarket central locking installed, so the speaker wires were used for the lock motors. I just put my speakers in the empty carpet window panels behind the seats (2 seater panel van).
This is going to sound stupid
Last Post: gotoberlin
Today 01:06 PM
Timing belt changing tips for 2.0 hdi
Today 01:01 PM
Towing weight
Last Post: martinbrown1223
Today 11:36 AM
under engine cover fabrication and repairs
Last Post: saskak
Today 09:54 AM
Speed Limiter Throttle Pedal.
Last Post: cancunia
Today 09:31 AM
MK1 tail gate inside cover removel
Last Post: Little boy blue
Today 07:25 AM
Radio code
Last Post: Tomcat3
Today 06:46 AM
How easy is removing the gear knob?
Last Post: ffrenchie
Today 06:34 AM
Another air con problem
Yesterday 10:16 PM
FRIGHTENING NOISES
Last Post: THE BADGE
Yesterday 02:51 PM
