2006 Berlingo Multispace Desire vs Alpine CDE-193BT
Hi there,
I'm having some problems with an Alpine Stereo I got installed by Halfords. It was a complete nightmare with them so in the end I gave up.
Basically, when I start the car, the radio doesn't remember any of my settings (saved radio stations, paired Bluetooth devices, etc) and I need to set everything up every time I start the car.
Another problem I'm having is that the built-in screen that displays the time and date and tells you stuff like "Front left door open" is stuck. When I start the car the time shown is correct, but it then just stays and does not show the current time. It's strange because the car "knows" the time when I start it every time but not when it's on... so if I start the car and it says 14:21 and I drive for 2 hours, the time is stuck in 14:21 until I switch off the car.
The stereo model is Alpine CDE-193BT: http://www.halfords.com/technology/car-a...-bluetooth
I just want to know if any of you have had a similar problem. I think it's got to do with the wiring because at the beginning the stereo would remember my settings, it was when Halfords were trying to "fix" the problem with the built-in screen that they made everything worse.
Any help would be appreciated.
Thanks!
Alex
[-] The following 1 user says Thank You to elmediano for this post:
  • drc200
Hi Alex welcome to the forum, You need have not got a permanent live to the radio just an ignition live. It can be fixed by swapping around wires in the plug or get the correct patch lead. Same goes for the centre display. Have a search on the forum there is loads about your problem.
This thread gives you alot of information on how to install an aftermarket radio, using the original radio stalk, display, etc
https://www.berlingoforum.com/thread-13310.html
Hi Tomcat3 and mendemizo,
Thanks a lot for getting back and for your suggestions. I'll have a look and see how it goes.
I've also been told that installing a can-bus interface would probably fix all that, so I'm also looking into that Smile
I'll report how it goes!
Cheers
Alex
Last Post: magoo1
Yesterday 06:31 PM
» Replies: 74
Last Post: Dyane6
Yesterday 05:19 PM
1.6hdi starting problem
14-10-2026 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
