Pads installed incorrectly ?
Had an occasional high pitched noise coming from the rear brake, which i put on the long finger to sort out.
Anyways its sounding a little different today, more like rubbing almost,
Does this pad look OK in the Pic ? it seems to be touching the rusty inside part of the disk.
Very difficult to tell but i can see what you are saying - remove pads check, copper slip, give face a rub on some emery cloth, check for pistons sticking, handbrake cable free play, refit and try.
Hello - your image looks like the pad is wearing in a wedge shape? If it is and your Berlingo has the same rear pads as the Citroen C4/C5 (no idea as mine has drums) then you may have a missaligned caliper due to corrosion of the caliper.
If it is a wedgie then Googling Citroen rear caliper wedge may assist.
              2008 1.6  HDi 110 Mini (Hers)
              2008 1.6  HDi 143 Mini (His)
I agree with GraemeT, the pad looks like it's wearing in a wedge shape.
If you look closely you can see a reflection of the pad in the disc, at the left hand side you can see that there is a gap between the pad and disc.
On the plus side the disc looks in great condition - might the edge of the pad just be a bit crumbly rather than wedge shaped ?- pads are very cheap these days (but buy a recognised brand) and normally you'd throw away the discs at the same time as a pad change, but in this case well worth changing pads and putting a smear of copperslip on the backs of them. Also a chance to check that the caliper pistons move freely and generally clean up the caliper. Allow a morning to do a thorough job on both rear brakes. If you discover a caliper problem and don't feel confident to do more, put the old pads back in and hand it over to a garage.
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
