[Engine] crankshaft oil seal leaking
Hi I have a 1998 birlingo with a 1.9 d engine, i have just had fitted bottom pulley and new belts two weeks ago now just noticed an oil leak AA man said it looks like the crankshaft oil seal , is this a big job as iv'e  just spent fortune at my Citroen guy?
Cheers Mick Angry
Yes and no Mick, easy to change the oil seal but the cambelt must be removed to do it
  • poldark41
(13-07-2017, 04:54 PM)polar Wrote:  Yes and no Mick, easy to change the oil seal but the cambelt must be removed to do it
Oh great thanks Polar for the encouraging news,
the citroen guy did all the work on the cam belt etc so Ill just have to let him do it, since he  did all the work i also have a clatter coming from the tensioner he said it was a little vibration and it goes away when you press the accelerator just slightly but its noisy so maybe he can sort it at the same time. I just hope it's not too expensive as its 19 years old and iv'e just had the front suspension upgraded.
Thanks Again Smile
Thanks Again Smile
does the bottom pulley have to be removed again?
Yes the pulley must come off
(13-07-2017, 08:23 PM)geoff Wrote:  Yes the pulley must come off
Thanks Geof
M59 unlocking itself
05-11-2025 04:06 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
03-11-2025 08:08 PM
02-11-2025 07:53 PM
Boot liner with 7 seats
31-10-2025 07:57 PM
Last Post: Buki
31-10-2025 07:26 PM
31-10-2025 03:06 AM
» Replies: 40
