Threads: 7
Thanks Received: 2 in 1 posts
Thanks Given: 4
I am stripping the engine down on a seized 1.9d (non turbo) Berlingo, parts removed and available are:-Cylinder Head with glow plugs and injectors, injection pump, manifolds, camshaft and coolant hoses. Happy to post photos of parts that are of any interest to people,I am in Cornwall but will parcel up and send anything anywhere. The engine has seized bottom end so everything I have removed so far is ok to use again,
The following 2 users say Thank You to cooter for this post:2 users say Thank You to cooter for this post
• jamesg, jj9
Threads: 6
Thanks Received: 16 in 13 posts
Thanks Given: 11
I'm missing something quite small, but if you have it!!
Bolt that is shared between water pump and camshaft timing belt cover??
Threads: 7
Thanks Given: 4
it must be there, I will have a look when I get home and let you know
Threads: 6
Thanks Received: 1 in 1 posts
Have you still got the gearbox?
If it ain't broke, don't 'fix' it.
Thanks Received: 3 in 3 posts
Don't suppose you've got the timing belt cover?
Thanks Received: 3 in 2 posts
Have you got the tps that sits on top of the pump
Threads: 23
Thanks Given: 46
5
The OP has not been on for over a year now
Threads: 48
Thanks Given: 4
20
you could try the Email or PM buttons. One of those might geta response. But given how long since he started breaking it, odds are that the only answer will be 'sorry mate, can't help you'.
Some other cars also used this engine so it's possible that doing alternate searches will work.
The following 1 user says Thank You to Gadgetman for this post:1 user says Thank You to Gadgetman for this post
• Art b
