Speedo needle -How to adjust
Hello guys,
I decided to clean the dust from behind the speedo clock and the speed needle is now in wrong position.
How would you approach this ?
2013 Peugeot Partner 1.6 eHDI Automatic
Put the dust back Big Grin Do you mean you cleaned inside the speedo glass ? If you did can you get back in and push the needle back to the correct position.
(02-08-2017, 08:28 AM)ffrenchie Wrote:  Put the dust back Big Grin Do you mean you cleaned inside the speedo glass ? If you did can you get back in and push the needle back to the correct position.
I will, but was just wondering if there is no way to move the needle into position without dismantling everything again.
This is really strange but yesterday I went to the car and the speedo needle was on zero and working correctly.
How is this possible ? The needle was at around 6 o'clock position when still, moving when driving, showing wrong speed, two days later it was at around 4 o'clock when till and again moving and showing wrong speed.
Not all is correct and I am wondering how ?
Warranty on parts
Yesterday 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
02-08-2026 02:22 PM
Berlingo 2026
Last Post: xtimex
29-07-2026 03:34 AM
