06-08-2017, 06:46 PM
I've just become a Berlingo owner after purchasing a 2005 2.0 HDI Multispace Desire from a local individual. It's actually the first car I've owned as I've had the use of my parents' cars since I started driving so I've never had much incentive to buy one for myself, although I've been set on getting a Berlingo for a while as I wanted something that was pretty basic, van-like, hard wearing and spacious to transport stuff like DIY tools and materials, bikes, camping equipment and a couple of dogs, so I was happy to enough to buy a cheap one when I had the chance.
However, it needs a few things doing to it. I'm going to list them here and post updates as I work my way through the list fixing everything - and hopefully anyone who's fixed these things before or just with more general knowledge about the car can chime in and help me out. I have no experience with car maintenance, simply because I haven't owned a car before, but I'm generally good at fixing things and want to extend that to cars. So, armed with a Haynes manual, a basic socket set and a can of WD40, here we go -
Help/advice and general morale support on any or all of these things much appreciated!
- Clean the interior - seats, carpets, dash, windows, boot, modutop, etc. The car is pretty dirty - and it's always worse when it's not your dirt - so it needs a good going over. I'm going to remove the seats to shampoo them and also be able to vacuum the carpets thoroughly and shampoo them.
- Fix driver's seat armrest - it's just hanging there. Should be easier to fix when the seat is removed.
- Fix passenger seatbelt - it's missing the button that holds the clasp in place at the top of the seat.
- Replace the audio head unit with something that my phone can connect to - either 3.5mm in, USB or Bluetooth - preferably while preserving LCD display and steering wheel control functionality.
- Fix brake light - passenger/nearside is not working, probably just needs a new bulb.
- Fix rear overhead compartment - it's not closing properly on the right side.
- Fix remote locking on key fob - both buttons are missing, both from the fob cover and the PCB inside.
- Get a new spare tyre - existing one needs replacing as it's really worn down on the inside. Need to get a new one and put it on the wheel.
- Fix or replace the bolt that holds the spare tyre in place - it's pretty badly rusted/seized so won't turn.
- Replace front right/driver/offside fog light - it's got a patch riveted over it so that needs removing. Assume the light behind it is either smashed or missing.
- Get a dog guard - preferably one that will fit whether the back seats are up or down.
- Replace oil and filters - a service is due so engine oil and oil, fuel and air/pollen filters will need replacing. Possibly also brake fluid.
- Check the condition of the auxiliary drivebelt.
- Replace rear axle trailing arm bearings - car is creaking/groaning at the back left whenever I set off and also has a negative camber on the wheel there. From everything I've read that's the bearing in the trailing arm, so the left one definitely needs replacing and the right one probably should be too.
- [Possibly related to above - car is juddering slightly at 60-70mph. It happens in 4th and 5th gear so is speed related, not gear dependent. I suspect it's the negative camber on the back wheel so hopefully this will be fixed with above.]
- New timing belt - not sure if this has ever been done on this car, certainly not in the last 5-6 years that I have service history for.
