[Warning Light] red STOP light flashing and beeping
ive got a 2004 berlingo multispace 1.9d and just recently when i brake it beeps 3 times and the big red STOP light flashes 3 times at the same time, also the brake symbol is on until the third beep then goes out Huh Huh Huh  anybody any ideas
Brake fluid level?
As cancunia says, top up your fluid reservoir
Hi,
My van would also do this, particularly when going down a steep hill, when braking the Handbrake light would come up, & I would get a single 'bleep', this was due to the brake fluid being slightly low, as for the 'STOP' light showing, maybe this is an extra warning,
being a later model than mine,
hope this helps.
Mk1, 1.9D, Admiral Blue, 51 Plate.
As advised check the brake fluid level.
If the level is low you need to find out why, it can be as simple as the the brake pads / brake shoes are worn down low or in the case of brake shoes (Rear Drums) it could be the self adjusters aren't working correctly.
It could also be a fluid leak from somewhere so best have a look under the car and pay attention to the wheel areas.
(10-08-2017, 12:05 PM)THE BADGE Wrote:  Hi,
hope this helps.
i topped it up and it did cure it but i wondered why it needed so much fluid and i checked the back wheels and a brake cylinder was leaking so changed it and the shoes as they were soaked, thanks for all the replys....
[-] The following 1 user says Thank You to gaz probert for this post:
  • jj9
Good that you found the leak and cured it.  Wink
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
