1.9d rattle , Power steering
My 1.9d has a rattle / metal knocking sound which I think is the drive belt area lower down. If I put a bit of steering on or hold it in full lock the noise disappeares so I'm guessing I need to be investigating the pulleys and power steering pump?
Any advice appreciated
Danny
Sent from my XT1068 using Tapatalk
Danny i think there is an idler which will tension both the PS pump and alternator . When the bearing in this wears it produces a fair bit of a rattle . easy way is to take aux drive belt off and spin/rock the pulley as wear shows up by grumble/rocking. Run the engine without the belt and if noise disappears it narrows the source down. Not expensive and straightforward to replace.
  • dannybee
Cheers
I'm gonna investigate Monday when I'm off , Had a look in manual and see what you mean about tensioner.
Well noise goes off when you remove the belt or load up the power steering . Booked it in for cambelt and pump doing with local garage who is going to look at the rattle too as all the pulleys etc felt / looked ok
Yesterday 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
