Airbag light always on
Just bear with me, I know this had been discussed so many times.
So my airbag light is always on. I found a broken wire under the driver seat in the brown connector. I soldered back, still light on.
So I thought: try the horn with ignition off. Works. Is this normal or earth is playing up behind the airbag?
I tried to remove the airbag, but no luck.
I changed the head gasket, cleaned the brakes calipers, bleeded the system, changed coolant thermostat and so on, but those effin retaining clips! I hate them genuinely! I hate them on my bike and officially on the car too!
The car is 2004 1.4 multispace.
Tomorrow I will ask the garage close to my workplace, if they say something silly money I need to do it because my MOT runs out on Monday and this is my commuter!
So the question: do I need to stick the screwdriver from the dash or try from the back of the steering wheel(paralel)?
Thanks in advance
Sent from my HTC 10 using Tapatalk
You will need to reset the airbag after doing any work on the wiring.
Ok, how I do that? I disconnected the battery.
No you need some kind of diagnostic kit or a code reader and reset unit.
Just like I thought, iI will try the garage tomorrow. Thank you!
No worries Tpeti hope you sort it mate
Airbag light : check the connections at the seatbelt pre-tensioner as this will throw up the same dash light fault, I had this and the airbag light went out with no need to reset with a diagnostic unit.
So what garage said: there is an open circuit on driver side airbag. This could mean: earth, unplugged connector.
If I cannot remove the airbag, would be enough just to put an earth wire somewhere?(steering column and earth)
There may not be a quick fix for this, if you have checked the usual problematic connections under the drivers seat, it will need diagnostic investigation of wiring and connections using a circuit diagram and test meter.
I had a similar problem on my Partner van, it proved to be a broken wire in the loom between the body and engine bay fuse boxes, which was one wire of the red and white pair carrying the data signal.
It took me a whole day to trace it and I'm a telecoms engineer and do this type of thing for a living.
[-] The following 1 user says Thank You to Roadie for this post:
  • Tpeti
I have got a test meter and wiring diagram, but I know just the basic, but I can use the meter.
We will see today, I will try have a look behind the airbag unit.
10-11-2026 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
