How do I disable my car.
What can I do mechanically to my 1.9D to disable it when I go on holiday, On my previous car, a Corsa, I would remove the adjuster on the clutch cable.
Slip off the clutch cable at gearbox end - quick and easy.
Remove the quick fit fuel pipe to the filter unit - very quick but you'd need to bleed it afterwards.
Is disconnecting the battery too simple ?
Pull off a multiplug eg BSI and leave it looking like it is in place.
Memory tells me there is a wire going to the pump somewhere unclipping this stops the engine, sorry canot be more clear without looking at the book.
Thanks for the response Geoff, good ideas, I was trying to stay away from the electrics with it being a bit French.
You're welcome but remember don't update this thread with your eventual method of choice !!
Heres another for you with only a cable tie needed - on the pump you have the manual stop lever so use a cable tie to hold it hard over to the stop position, car will never start and rectified with a snip from a cutters.
Use a black cable tie rather than white so it is less visible.
Yesterday 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
04-09-2026 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
