[Steering & Suspension] Rear Spring Replacement
Had to replace my rear springs today as one of them decided to snap near the base.
Quite an easy job as the springs sit separate from the rear shocks.
Only problems were couldn't really get the normal small spring compressors located into place as there are too many obstructions [top and bottom mounting plates] and there isn't enough room to really space them evenly, to the point I didn't really feel safe, so I invested in a set of these
Yes, quite hefty and cost about £60, but better than having a spring in the face! Made the job a lot easier [and I'll also use them when I do  my top mounts at the front  Wink ]
Only other slight problem was the upper rubber stops are a very tight fit and needed some silicone grease to release from the old springs.
Bought Kilen replacement springs [Made in Sweden] and paid about £70 for the pair.
Also make sure you have the correct springs, mine were the HD version for a Berlingo Multispace with AC and a Glass roof.
Didn't know the berlingo had rear springs , I thought all models had torsion bars .
Live and learn
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(14-08-2017, 07:10 PM)brodfather11 Wrote:  Didn't know the berlingo had rear springs , I thought all models had torsion bars .
Live and learn
M49 and M59 Torsion bars
B9 Coil springs
[-] The following 1 user says Thank You to Multispacer for this post:
  • brodfather11
If you remove both shock absorbers can you drop the axle enough to put the spring in without compressing as we did on my daughter's Corsa ?
(15-08-2017, 07:32 AM)ffrenchie Wrote:  If you remove both shock absorbers can you drop the axle enough to put the spring in without compressing as we did on my daughter's Corsa ?
On the side with the broken spring, yes  Smile but on the other side that still had the spring intact, I needed the compressors. Also be careful to support the axle so as not to put strain on the brake pipes etc.
Rear door filling with water
Today 06:56 PM
MOT Emissions repeated fail
Today 06:53 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
