[Sold] 2017 15" Steel Wheels, Tyres & Wheltrims, As New.
Threads: 6
Thanks Received: 8 in 8 posts
Thanks Given: 23
14-08-2017, 06:04 PM
(This post was last modified: 14-05-2018, 05:55 PM by davester65.)
Having just replaced the stock 15" wheels on my new van with Alloys I now have a set of 4 x 15" Steel Wheels with 195 65r 15 Kleber Dynaxer HP3 Tyres and the current 2016/17 Berlingo Van Wheel Trims (see pic).
I only got my new van last week so I would describe this kit as Brand New -250 miles, (alloys fitted with 232 miles on the clock), so almost as new, just a bit of brake dust to wash off, wheeltrims are unmarked.
After Googling around best prices I can find are around £45 per tyre, £35 per rim & about £10 per wheel trim, so total price of this kit new would be north of £350.
Asking £200 ovno for the whole set, buyer to collect from Hull E Yorks.
Threads: 6
Thanks Given: 23
(19-08-2017, 10:06 AM)zahra1234 Wrote: use this site u can also sell and buy wheels and tyres
http://www.gari.pk/accessories/c-Alloy-Wheels/
errr......I'm in .uk not .pk thanks for the bump though :-)
Threads: 23
Thanks Given: 46
5
I cannot work out if you are being 'helpful' or spamming this site. I hope its the first.
Do you really think that people in the UK would buy wheels from Pakistan?
i dread to imagine the postal cost involved?
The following 1 user says Thank You to Trevor for this post:1 user says Thank You to Trevor for this post
• davester65
Threads: 9
Thanks Given: 316
15
(21-08-2017, 10:12 AM)Trevor Wrote: I cannot work out if you are being 'helpful' or spamming this site. I hope its the first.
Ive reported him as a spammer
• davester65
Threads: 5
Thanks Received: 1 in 1 posts
Thanks Given: 1
(21-08-2017, 02:39 PM)polar Wrote: (21-08-2017, 10:12 AM)Trevor Wrote: I cannot work out if you are being 'helpful' or spamming this site. I hope its the first.
Hi, the tyres are the right size for my transit connect - do you know if the rims will fit? Or, would you sell the tyres on their own? Thanks
Threads: 9
Thanks Given: 316
15
Er i think you need to post this to the OP
Threads: 6
Thanks Given: 23
@ BERLINGO_CHRIS, not sure if the rims will fit your transit, the citroen wheels are a 4 stud fitment if that helps. Don't think I could sell them separately as I have no way of getting them off the rims.
Threads: 3
Thanks Received: 7 in 7 posts
Thanks Given: 3
Hello,
I own a 2008 m59 Berlingo that currently have 14" wheels.
I am interested in buying these if they fit and still are available.
Please let me know.
Threads: 7
Thanks Received: 210 in 121 posts
Thanks Given: 16
9
B9 wheels will fit M59 vehicles, as long as the tyre width is 195 or less. Depending on model spec.
I have both a B9 Multispace and a M59 Multispace, and my B9 steels are 215/55 x 16 with 6.5j wheels. Offset and stud pattern are the same for both vehicles.
The M59 has 15" wheels, but putting the B9 16" steels on my M59, the fronts are great, but the rears just touch the inner arch on the sidewalls. That's with 215 width tyres.
I could put 5mm spacers on the back, and use the 215 width tyres, but now I've gone down to 195 width tyres, there is no problem.
Hope that helps someone.
Gravity
Threads: 3
Thanks Given: 3
(17-02-2018, 07:24 PM)Gravity Wrote: B9 wheels will fit M59 vehicles, as long as the tyre width is 195 or less. Depending on model spec.
Gravity @ gravity,
Thanks for your response!
I have been thinking about this upgrade for a while and you have now confirmed that it is possible.
Now to find out if I can fit m59 multispace roof rails and front bumper foglights to my van?
I am just considering fitting LED headlight bulbs in my van to improve night visibility.
Today 02:32 PM
Berlingo 2026
Last Post: xtimex
Today 05:06 AM
Yesterday 12:15 AM
Yesterday 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
Weird Air in Fuel Problem
Last Post: tomhick024
27-06-2026 03:25 PM
