  • 6 Vote(s) - 2.33 Average
Newbie
Hi folks, just signing in, had a Berlingo since 2002, Its now starting to fall to bits, hopefully I will be able to draw on collectives experience to keep it on the road.
regards,
Jimmy
Hi Jimmy and welcome. Hopefully nothing major has gone south yet. How many miles have you got on the clock?
(05-11-2011, 08:44 AM)3rensho Wrote:  Hi Jimmy and welcome. Hopefully nothing major has gone south yet. How many miles have you got on the clock?
80K on the clock, I changed the timing belt at 70K, front springs about 5K ago other than being a bit shabby its running fairly well.
There is a bad smell on the inside when the heater is on ( I suspect a leak in the matrix) and the air con compressor is cycling on and off.
I need to investigate the leak as the smell is getting on my nerves now.
The matrix leak is a common problem and also same on my 2004.
It's supposed to be a pig of a job to sort, so I will just live with the spicy curry smell!!
Welcome to the site Diamad, :wave:
Welcome to the forum mate!
Yesterday 12:21 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
17-10-2026 05:41 PM
