how do i change the door lock pins?
Wink
I want to change the worn out door lock pins to some small skulls...
The skulls have round bases, and the berlingo oval... should i take the anglegrinder or twist with force to remove the old, so i can change them?
Thinking of attaching them with some superglue after removal...
Any tips out there? Smile
(16-08-2017, 11:57 AM)densortefane Wrote:  I want to change the worn out door lock pins to some small skulls...
Cant get my head around what you mean   Huh
There may be a language/description problem or it could be me Exclamation
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
It took a bit of working out but I think he means the door lock push buttons on drivers and passenger door that you push down to lock and pull up to undo. If it was me I would make the button top flat then use one of the glues that set by ultra violet light to bond the button and skull together. Ive used that glue quite a lot lately and it is miles better than superglue.
Ok, tnx for the answer Smile
Coolant
Last Post: tomhick024
Yesterday 06:18 PM
SOLVED: P20F6 fault
Yesterday 08:28 AM
Leaking windscreen or aerial
15-04-2026 08:50 PM
