  • 25 Vote(s) - 3.28 Average
Berlingo Fault Codes
Hi Folks, In relation to OBD fault codes, does anyone know where I can get a list of the manufacturers specific fault codes for a Mk1 1.4 Berlingo Multispace as opposed to the generic ones that I already have. I don't have a problem (yet!) but would like to be ready.
Cheers,
Griff:wave:
Landmark
Ex 1.4 Berlingo Multispace
Hi Landmark.
What engine? CNG, LPG, with one or two carbs?
If it's a inj engine, who made ecu? MM, Bosch, Sagem?
Please, provide us a type or model of ecu.
(06-11-2011, 06:21 AM)pk7478 Wrote:  Hi Landmark.
Hi PK, It's a 2002 1.4 petrol with injetion. How do I find ecu make? Would a PM of the vin no. help?
Regards,
Griff
Landmark
http://www.bba-reman.com/content.aspx?co...ault_codes
ive found this site in my searches dont know if its any good to you as im not that far down the line at the moment myself to check .
what reader you got landmark and do you recommend .
thanks
Hi Wertyu2007,
Many thanks for that, it seems what needed.
I've just bought an Autel MaxiScan MS509 (about £80) to try and sort out a problem of overheating with our 2002 1.4 petrol Mk1 Multispace. The only error code it throws up is a generic "P0130 O2 Sensor Circuit Bank 1 Sensor 1"
It's been into several garages, who have replaced various sensors, but it still happens if you get stuck in traffic. I think it's the fans not cutting in but I'm never there to check if the're running when it happens.
Regards,
Griff
Landmark
hi mate
thanks for reply on reader ill have look at that .
my sisters peugeot always throws up that code but runs fine could just be going over the lamda sensors limits known and again throwing up that code or just need a good service but not certain on that just a guess , id imagine that its a coincidence the overheating and the code .
http://www.permoveo.ltd.uk/tabid/122/OBD...fault.aspx
if i was you id just go through usual with overheating issues radiator , pump , fans , fan switches and relays etc.
my citroen relay van did the same overheated all te time it was the fan switch on eside of radiator when i finally got around to working on it.
good luck
barry
[-] The following 2 users say Thank You to wertyu2007 for this post:
  • Landmark, UpDownUnder
Today 05:26 PM
Air filter box removal
Last Post: Harrythephot
Yesterday 11:03 PM
Berlingo undertray
Yesterday 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
