Threads: 12
Thanks Received: 4 in 4 posts
Thanks Given: 3
Not for a camper conversation but I figured you guys and girls would be best people to ask.
I've successfully tinted my rear side windows ( need to move my trials bike without it being on display) however I could not get the rear upto scratch. Anyone tried alternatives I thought about a curtain type setup maybe using suction or even some black 3m vinyl wrap on the outside as I have wrapped stuff in the past with success.
Cheers
Danny
Sent from my XT1068 using Tapatalk
Threads: 12
Thanks Given: 3
Hi,
Yes it came of easily on the rear as it was still wet I could tell it was beyond my ability ! That said I never tried the heat method so so give that a go and let me know how you get on lol
As for the side windows i removed them from the car and did them on wheelie bin, I don't think I would have got a good finish doing them in situ. There really easy to remove 3 screws in each window from memory there a torq fitting as opposed the usual flathead or posi drive.
Threads: 5
Thanks Received: 5 in 3 posts
Threads: 7
Thanks Received: 210 in 121 posts
Thanks Given: 16
9
04-10-2017, 12:27 PM
(This post was last modified: 04-10-2017, 12:28 PM by Gravity.)
Dan,
That's a great idea.
Which magnets did you use? There seem to be so many sizes.
Gravity
Threads: 48
Thanks Given: 4
20
Please take note of the 'N52'.
This is a 'strength rating' of the magnet.
The same magnets may also be found with rating as low as N35.
(Scale goes from N35 to N52 )
Higher N-ratings usually means more expensive magnets, but they're worth it since a N35 might have had to be nearly 4mm thick to generate the same holding force.
Or you'd have to use more of them.
If the rating isn't listed, particularly on eBay sales, odds are that they're the weaker versions.
