Anyone who's actually replaced an engine
Ok let's put it another way has anyone fitted a replacement engine in an M59? If so a) did you fit one with the same code number? If yes did it fire straight up or need anything resetting? If you didn't fit one with the same code a) what problems if any did you encounter? b) did you use the diner parts like injectors or fit the old ones? Thanks
Yesterday 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
