Threads: 9
Thanks Received: 9 in 9 posts
Thanks Given: 12
So, just reached 100k and got a warning - Additive low (DPF ) so anyone else had this and what did you do ?
I can get the additive fitted or another option is possible DPF delete and map as although its not a DPF issue how long until it is ?
Threads: 9
Thanks Given: 316
15
You can top up your bag with eloys fluid its not expensive but it is extremely corrosive and you must wear gloves and eye protection. When this is done you need to get someone to reset the warning.
Threads: 12
Thanks Received: 386 in 274 posts
Thanks Given: 16
37
I think we may have already discussed this .
It won't be long before the dpf is finished anyway, you can get an exchange one from Citroen, I would not fit aftermarket , they are poor quality.
Filling the tank is a little fiddly, but easy enough. You will need diagbox to clear the light & reprogram the additive Ecu .
