Intro New member
I think your site is brilliant for info. I live on Portland. Dorset. I joined because I have just fixed an airbag fault and wanted to share what I found. I had a P1211 FRONT LEFT Satellite. I have spent hours trying to find out about it. I won't go into all the twists and turns but from the research I pieced together that it was the side impact sensor of my 2007 Berlingo. It was located bolted to the inside sill just in front of the front passenger seat floor fixing bolt. After taking off inside trim I removed sensor and unplugged cable. The carpet was wet here(left window open in rain). Unit looked dry. Tested across pins of sensor only when disconnected. No reading either way. >2Mohms. Right hand sensor same.Dryed up carpet,plug and socket then lightly sprayed with WD 40. Reassembled and fault cleared. Conclusion. Damp in the connections causing bad connection. Facts. Sensor will cost around £64 from dealer. ACU £350. This Berlingo model has the front impact sensor built into ACU. So research time well spent. Thanks once again to all contributors. and I heeded warnings. PB
[-] The following 1 user says Thank You to Portland Boy for this post:
  • Tomcat3
Thanks for sharing ....
  • Portland Boy
Your welcome. I need to study the site much more to find out its construction so I can make best use of it. Ty PB.
Where is 2011 Berlingo parking sensor ECU?
Last Post: Gene1
Yesterday 09:28 PM
BSI
Last Post: jemselectrical
Yesterday 08:53 PM
» Replies: 16
M59 BSI Technical Document (Citroen Training)
Last Post: Zion
Yesterday 07:07 PM
Cup Holder Fitting
Last Post: Gadgetman
Yesterday 05:54 PM
Electric probs - where to start
Last Post: BigVtwin996
Yesterday 05:26 PM
Stuck glow plug tip - I've tried it all - It won...
Last Post: DeSender
Yesterday 05:15 PM
Berlingo/partner 2019 Gearbox real or fake?
Last Post: Zion
Yesterday 04:59 PM
Removing footwell carpet - problem
Yesterday 09:05 AM
Rear back door air gap??
Last Post: Gene1
Yesterday 08:24 AM
Problème ABS
Last Post: Zion
Yesterday 07:36 AM
