30-08-2017, 02:16 PM
(This post was last modified: 02-09-2017, 11:29 AM by BerlingoBoyo.
Edit Reason: found and fixed fault
BERLINGO VP (M59) FOURGONNETTE FAMILIALE 1.9 D 71 (DW8B) BVM 5
After a recent master cylinder replacement my airbag light came on - is there a clue here?
The mechanic said coincidence and checked the under seat airbag wiring. And pronounced all well.
I thought I would check and take a picture. This image is of the wiring under the driver's seat, the passenger seat only has the brown wiring.
I had to cut the 4mm cable ties to free up the wiring enough to get it out.
Cleaned and re-joined firmly - light still on.
[Image: Berlingo-airbag-underseat-connectors.jpg]
The scanner says -
0F40 VAN network 140F40
006F Passengers airbag Inhibition 14006F
This doesn't seem to be a common code, though I have read a thread that pointed to a wiring fault between the BSI and the airbag circuitry.
The BSI is easy to find - it's below the steering wheel behind a panel that just pulls off. I took another photo.
[Image: Berlingo-BSI-location.jpg]
I'm not sure what to do next -
I have read that the airbag ecu is under the gear stick shroud - should I try to test the connections between the two for continuity?
How easy is it to get the BSI out ?
OR
I have read somewhere about a harness near the air intake that rubs through. I have also had lots of issues with the blower motor - might the problem be in that area?
ta like.
BB
The scanner says -
OR
ta like.
BB
