Hi, my buddy's 2006 diesel Berlingo van has the engine warning light on all the time.
So I tried pugging in my USB ELM327 OBD2 reader device & fired up it's supplied software (Gendan Engine Check Pro)
Tried connecting - seemed to connect just fine.
Tried reading fault codes - it did 'something' but no codes were displayed. It seemed to be reading things like engine rpm, coolant temperature ok though. & it did seem to pick up on the engine warning lamp being 'on'.
Tried 'clearing fault codes' even though there didnt seem to be any - this had the effect of the software subsequently reporting the engine warning light to be 'off'.
Didn't actually turn off the light on the dash though.
Read around a bit, had some help, & came to the conclusion I need proper software and hardware to talk to the Citroen 'properly'.
Tried my favourite local mobile mechanic but he's only got the generic ELM327 reader himself.
Found I have a CD left over from an earlier encounter with a Citroen Dispatch van, "Lexia 3 v45". I'd noted back then, in sharpie marker on the CD, that "this needs a special cable, Actia, PSA Evolution X5 interface etc". Never used it. IIRC I thought I needed it to configure the CAN bus, something to do with volume controls on a radio I was fitting, in the end all I needed for that was an interface box of tricks that just plugged straight into the back of the radio with no config necessary. So I never investigated Lexia any further.
Seems from looking around the 'net and on ebay etc, there's a wide range of options for different hardwares and softwares to talk to the Citroen OBD. Diagbox hardware, Lexia hardware, different levels of software etc etc. Although I've got a Lexia CD it looks like most of these options come with software included?
Given that all I want to do is connect successfully to the basic extent necessary to find the cause of the warning light being on, fix the problem, and hopefully turn the light off, what's the cheapest options for my circumstance? Been looking at eBay item number: 122586086176; am I on the right track?
