  • 21 Vote(s) - 2.95 Average
battery/alternator
Hi guys
A week after buying my berlingo ....it has now developed to faults and im hopimg its just something simple or me being an unlucky sod with motors
After a nighttime drive of approx144 miles the next day the battery light on the dash came on and it was difficult to start
After charging in up for approx seven hours the return trip it came on again about half of the journey back with no lights on or heater just the radio and then the airbag light came on
Battery or alternator just seeing if anyone else has had this problem
Nidge
First have the battery tested if it tests OK then you're probably looking at the alternator. On the bright side it may just be the battery/alternator connections or cables,
as it's quite common to get poor earth connections due to corrosion or simply that the earthing connector bolts are loose.
  • Andre
Thanks O J
it was just a question for peace of mind really i am getting it checked tomorrow cuz i love the van also
(06-11-2011, 06:39 PM)nidge44 Wrote:  Battery or alternator just seeing if anyone else has had this problem
Nidge
Alternator. And namely it's voltage regulator.
Problem solved ......needed a new battery
Went to citroen dealer after and they said that the battery light only shows a faulty battery not if the alternator isnt charging and they tested both the old one (faulty cell) and the new one accepting charge when engine started up......couldn't have been more helpfull (citroen Orsett Cock Thurrock)
Hope it helps someone else
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
