[Engine] immobiliser problem?
i changed the battery on my 2001 berlingo now wont start. It turns over all lights etc work there is a flashing yellow light with a key on dash. It was running OK before i changed the battery. . Any ideas please. All the fusesfuses are ok thanks
Did you change the keyfob battery or the car battery?
The yellow key symbol means it can't read the chip in the key, the reason I ask about the remote key is you wouldn't be the first person to drop the chip out when changing the remote battery Wink
If it was the car battery your too early for a bsi reset to do anything as you dont have a bsi, I'd start by plugging it in and seeing what the immobiliser can see i.e. Can it see the transponder from the key and go from there!
[-] The following 1 user says Thank You to dumdum for this post:
  • agha
Some one sAid to me that the BSI HAS DROPPED THE INFORMATION ABOUT THE KEYS SO NEEDS REPROGRAMMING i tried the window down, disconnecting positive lead side lights etc procedure to no effect. My berlingo does not have central locking or any buttons on the keys so how can I get the BSI sorted thanks
id be inclined to take a feed from the power side of the reversing light wsitch on the top of the gearbox, its an ignition fed supply so comes on on the key,  and connect it to the fuel shut off solenoid on the injection pump.   car should then start and stop on the key.
youll still have the prettty light on the dash but xmas is coming.
V
aghaSome one sAid to me that the BSI  HAS DROPPED THE INFORMATION ABOUT THE KEYS SO NEEDS REPROGRAMMING i tried the window down, disconnecting positive lead side lights etc procedure to no effect. My berlingo does not have central locking or any buttons on the keys so how can I get the BSI sorted thanks
Have u looked for someone with Lexia?
Today 05:26 PM
Air filter box removal
Last Post: Harrythephot
Yesterday 11:03 PM
Berlingo undertray
Yesterday 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
