Threads: 5
Thanks Received: 3 in 3 posts
Thanks Given: 2
04-09-2017, 10:10 AM
(This post was last modified: 04-09-2017, 10:11 AM by nginmu.)
2006 Berlingo diesel van, non ABS
I've been quoted £44.40 for a rear wheel bearing, the factor tells me "it comes as like, a hub".
I have no hydraulic press but I do have a torque wrench and decent jacks and stands.
Is this a job I could do okay myself without a press?
Any common pitfalls to look out for?
Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 305
37
This may help you decided if if it's a job you could tackle yourself.
https://www.youtube.com/watch?v=6kSagl9ZSPE
The bloke in the video just pulls the old hub off by hand, you may find you will need a puller to get it off.
• nginmu
Threads: 8
Thanks Given: 305
37
Yeah the Pug partner is the same vehicle.
You tend to find stuff on youtube when your not looking for it, there's loads of berlingo videos on there but a lot of them are in Polish or Russian so the title is in that language!
The rear hub nut should be tightened to a specific torque setting -
Nut with separate thrust washer - 275 Nm / 203 lbf ft
Nut with integral thrust washer - 250 Nm / 185 lbf ft
If you don't have a torque wrench very tight is the setting, a 13 stone bloke (or woman
) standing on the end of a one foot extension bar will be close enough.
Threads: 5
Thanks Given: 2
04-09-2017, 05:06 PM
(This post was last modified: 04-09-2017, 05:07 PM by nginmu.)
Excellent thanks :-) I will use my calibrated missus
The following 1 user says Thank You to nginmu for this post:1 user says Thank You to nginmu for this post
• jj9
Threads: 8
Thanks Given: 305
37
Threads: 48
Thanks Given: 4
20
A Torque wrench may sound expensive, but in this case it can be the difference between 'lasts the rest of the car's lifetime' and 'what's that grinding noise?'
Threads: 8
Thanks Given: 305
37
05-09-2017, 09:57 AM
(This post was last modified: 05-09-2017, 09:58 AM by jj9.)
The average 1/2 inch drive torque wrench doesn't go up high enough to cover the settings for the rear (or front) hub nut, maybe there are some that do but they are going to be expensive.
Just use maths for tightening hub nuts, Foot Pounds (lbf ft) is a pound of weight applied one foot away from the nut, so 200 lbf ft is 200 pounds on a foot long bar or 100 pounds on a two foot bar. . . you can get close enough using this method.
Any bearing failure (the grinding noise you may here) will more than likely be down to the fact that we have bought a cheap bearing that has been made in China, for a quality rear hub bearing you will be looking at around the £100 mark, so we all just fit a cheaper one don't we.
Threads: 5
Thanks Given: 2
Now you mention it it's all coming back to me. I have a very rusty memory but now I remember having the same problem on a Ford Escort about 4 or 5 years ago, not being able to find a torque wrench big enough.
Nobody at the motor factors believed the torque figure I was trying to reach but Ford confirmed it.
Still got the torque wrench I got for that job so there's a chance that'll do the Berlingo hub.
Threads: 48
Thanks Given: 4
20
My Biltema-branded 1/2" cost me about £80. And it's a 2' long model.
There are also adapter that can be fitted to the torque wrench(looks like an open-ended spanner) to lengthen them and increase the torque range, but I'd avoid those if I can.
I've seen hub nuts listed with over 300Nm torque, so these are kind of 'mild', really.
If the guys at 'Motor Factors' don't believe these ranges, I'd really worry about their competency.
