Parking sensor fitting
Hi from a newbie
I have a Citroen berlingo multi space 1.4 2007
I am having a problem trying to connect front and rear parking sensors
I've got 5 wires at the rear 1-brown
2-yellow. 3- pink 4- white 5- thick yellow/green 6- light grey
Could anyone tell me which is red live blue brake yellow reversing I hope someone can help
Not quite sure what you mean but if you undo the rear light it's quite easy to see which metal strip is the earth & go's to all the bulbs & which are the live ones to each bulb. Then you can follow it to the wire
[-] The following 1 user says Thank You to East for this post:
  • Soggy
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
