  • 11 Vote(s) - 2.09 Average
preventitive maintenance
Wink
I'm considering next service to take out the wire gauze filter on the turbo pickup, can't take the risk that the turbo runs oil starved
So good idea or just leave it its working fine ffs
Also is there any other preventitive maintenance to consider
Mines the 1.6 hdi 07
(06-11-2011, 11:03 PM)corkgsxr Wrote:  I'm considering next service to take out the wire gauze filter on the turbo pickup, can't take the risk that the turbo runs oil starved
Also is there any other preventive maintenance to consider
HI, don't think that is really a good thing to do, if you change your engine oil regularly with the correct oil and filter etc, should be no problem.
now there is a problem with the HDI engine fuel filter,i think its 03 on, could be wrong, DW engines. if you take the top off and remove the filter from the bowl, have a good look you will see little brass particles in the bottom, drain bowl and clean out with airline or kitchen roll, don't use a rag, its those bits of brass that block the injectors up , this is good preventative maintenance, good luck.Confusedalut:
Leaking windscreen or aerial
Last Post: Guanajuato
Today 09:05 PM
Apple Carplay
02-04-2026 01:26 PM
