Electric windows
Hi I wanted to know does the one touch mode only work on drivers side window?,
and if the passenger side window is also one touch mode ,how to enable it or reset it.
I suspect the drivers side is one touch like mine - but mine is only one touch down not up. It may be able to be programed in with a lexia?
My car is one touch on the drivers side window but just a normal version on the passenger side.
Polar,
my drivers side is the same as yours, one touch down but not up, I thought that maybe the switch was dodgy and it should be one touch both ways?
Hi JJ to answer your question:
If they fitted one touch closing they would have to fit a more expensive window motor that has a anti finger trap sensor fitted so they fit a cheaper motor in vans and lower spec cars that are only one touch down.
  • jj9
Well that saves me a job changing the switch etc.  Big Grin
I never knew they were meant to be like that, so thanks for the info.  Wink
That's great information,i was puzzled as the owners manual says one touch electric windows ,so I assumed the passenger side was faulty,
mine also does the same one touch down not up driver side only.
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
