Threads: 2
HI. IM CURRENTLY WORKING ON A 2006 BERLINGO 1.9D. ON START UP THE BATTERY WARNING LIGHT REMAINS ILLUMINATED AND ALSO THE HANDBRAKE WARNING IS LIT WITH THE HANDBRAKE OFF. WHEN I DRIVE THE VAN AND THE SPEEDOMETER MOVES , BOTH WARNING LIGHTS GO OUT UNTIL I COME TO A STOP AGAIN THEN BOTH LIGHTS COME BACK ON. IT ALL SEEMS TO BE RELATED TO THE SPEEDO AS THE LIGHTS ARE OUT AS LONG AS THE VAN IS MOVING. THE HEATER ALSO STOPS AND STARTS WITH VEHICLE MOVEMENT. BATTERY IS CHARGING WHEN STATIONERY ACCORDING TO A MULTIMETER READING. CAN ANYONE HELP?
Threads: 52
Thanks Given: 87
5
Hi spannerman and welcome to the forum. When the van is stationary, in neutral, if you increase the revs to 1500 or so do the lights go out?? If so then I'd guess the voltage is too low and it increases with the higher revs when moving. Just a thought.
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 137
33
I'd be looking for loose earth wires ,(with the lights going out when the engine moves when vehicle moving ) possibly on the engine or the dashboard ones.
Or at the multiplugs on the engine fuse box .
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
